Re: 500-C Crawler engine problem, Timing???
Posted by doug in pa on July 09, 2007 at 06:37:06 from (4.155.129.103):
In Reply to: Re: 500-C Crawler engine problem, Timing??? posted by Janicholson on July 09, 2007 at 06:03:12:
I sort of decided its not fuel, since I do have fuel at the injectors. Also when I shot a lot of ether into the intake, it did nothing. It has compression, that you can feel by turning it over by hand. I just feel since the ether has no effect that its not even getting into the cylinder at the right time. Since I already have the timing cover off, I want to check everything mechanical to be sure before I attemt anything else.
Today's Featured Article - Tire Fluids - by Curtis von Fange. It came as a surprise. The tire on the tractor needed to be pulled off to get to the brakes for service. The tires were blocked, the rear end raised on jacks, the lugs loosened and the tire loosened from the hub. Then, as the big lugged circle of rubber slipped off the last wheel stud it became apparent that there was more there than just an empty tire. Four hundred pounds of rim, tire, and fluid dropped to the ground like a sack of wet cement. Fortunately the installer jumped out of the wa ... [Read Article]
