Re: valve lash/timing
Posted by CNKS on July 17, 2007 at 18:07:18 from (204.249.178.32):
In Reply to: Re: valve lash/timing posted by Mark Doud on July 17, 2007 at 17:44:12:
See the link, 0.014 hot for both intake and exhaust, maybe set them at 0.016-.017 cold, if it is a rebuilt engine, to start with, run it a few hours, retorque the head and set at 0.014 hot -- where did you get your information?
