Farmall C Timing Gear Question
Posted by Justin S. - TX on July 29, 2007 at 16:07:39 from (70.117.196.72):
I have a C that I recently restored and have been using for about 8 months, it was running great until i went to make some adjustments on the govenor and carb. The motor had been rebuilt by family members earlier. The engine turns great, but the the govenor, hydraulics, and distributor have stopped. By looking down the timing cover from the governor opening I can see the crank turn, but not the timing gears. What locks the timing gear to the crank? Is it going to be as simple as pulling off the front of the tractor and slipping in a small part,bolt, or will it mean a full overhaul? I have not ever gone that deep in the motor, any advice is greatly appreciated.
