Super A , magneto timing
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Carl on February 12, 2000 at 17:04:19 from (12.73.160.54):
Is there a proper way of timing the gears in the distributor body, or should I just get #1 TDC and when the impulse coupling clicks, just align the gears so the rotor is at #1? (I know, I should have marked them first)
The small gear has one tooth that looks to have a little machined off. Is this used to time them or is the tip of this tooth just broken?
When I put these back, should the housing be filled with axle grease or?
Thanks in advance
Post A Followup
: Re: Super A , magneto timing
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
