Re: Georgeky and Hugh MacKay..........Iiiiiiii did it! :)
Posted by Patrick Martin on August 08, 2007 at 20:35:29 from (64.154.26.250):
In Reply to: Georgeky and Hugh MacKay..........Iiiiiiii did it! :) posted by Patrick Martin on August 08, 2007 at 20:29:59:
Hey guys by the way, do these look OK? These are the brackets that I fabbed up for my lift arms. They did pick up my disks and bushog fine, do you think I need to go with something thicker?
third party image
Also, if you look on the lifitng bar (the black one, I coated it with POR-15). Is there supposed to be a spring on it and if so is the sleeve supposed to slide back and forth?
I tried heating it but it wouldn't budge so I guessed it must be permanently affixed there. If this is wrong I will go back and try to loosen it again. Let me know!
