Re: Georgeky and Hugh MacKay..........Iiiiiiii did it! :)
Posted by scotty on August 09, 2007 at 04:45:16 from (199.231.49.128):
In Reply to: Georgeky and Hugh MacKay..........Iiiiiiii did it! :) posted by Patrick Martin on August 08, 2007 at 20:29:59:
Mornin Pat,
Nice job ! My pump drive gear had worn the end of the pump shaft and I had to grind the end diameter down and press a new bushing on. I replaced the o-rings also, as with the whole touch control unit. The PTO rear seal was a bear as you say, I ended up pulling the whole unit off but managed to get it done. Remember that your kind of limited on the amount of weight that you can lift with that rear rockshaft ! Good luck with your new setup !
scotty
