Posted by JMOR on August 17, 2007 at 17:59:26 from (76.185.68.29):
8 foot Austin MFG. It has never cut worth anything since I got it (used). Sharpened several times, compared the RPM, gear box ratio to another that I have (single 5 ft) and when blade diameter is taken into account, both are 10,000 feet per minute tip speed (about same as found in eqmt catalogs). One cuts good, one poorly. The poor 8 foot has two rotating systems and now that I have checked and compared most things, I'm wondering that if it's earlier life, someone had it apart, swapped the gear boxes or something that would maybe cause the blades to rotate in opposite directions (yes the sharp edge hits the weeds first),but that is just flipping the blades over.)
As it stands now, the left rotates ccw & the right cw such that in the middle, it slings cuttings forward and on the outsides, it slings toward the rear. Anyone out there have a two head cutter and know directions of rotation or any other idea why this one cuts so much worse than the other? Should blade plane be level? The good one has a slight downward rake at the front, about 1 inch lower than the rear.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
