Re: bush hog, but I use an SMTA to pull it...
Posted by mower man on August 18, 2007 at 05:11:47 from (208.126.6.169):
In Reply to: bush hog, but I use an SMTA to pull it... posted by JMOR on August 17, 2007 at 17:59:26:
JD 1018 and HX19 mowers run that way. The blades run in opposite directions. Are the correct blades on the cutter that is not working well. They may not be providing any lift and knocking the weeds down.
Do you have a slip clutch that is not working? Or a shear pin out?
