Nawlens: The total capacity is only 5 quarts, and fill to level plug is on left just below front tip of left fender, usually behind the brake activation rod.
I know the newer manuals say hytran for transmission, however nothing changed in there since 1939, other than harder gears. As you know, 140s do not draw hydraulic oil from transmission as later larger tractors do, therefore gear oil is the way to go. Gear oil will make transmission quieter, will lubricate better and cause transmission gears to slow down faster after tractor has been idling in neutral.
Another thing I can tell you, having farmed all those years, before the days of hytran in transmissions, it was rare to see a tractor at the IH dealer shop with transmission or rear end opened up. Yes, the transmission reservoir did improve hydraulic function but I never figured hytran was a great friend of bearings or gears.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
