SH with H engine
Posted by nspec on September 10, 2007 at 13:22:38 from (72.87.118.244):
For anyone who read my previous posts, I have some better information.
Recap - I own a "53 super H, number 540J.
Engine has no c-164 cast into the block.
Cast into the block above the filter housing is the following - 6695 DE. (am told this is the cast code for the 152 block)
Below that, also cast is 2-BE. (not sure what that is)
Serial # prefix is IBHM. The "I" looks like an afterthought, or separate stamp.
Here"s the better info. I can now see that the date code is 9-9-M. I previously thought it to have an x code.
If I"m correct, the M makes it a "43. There is olive green paint under the yellow, which is under the red!!!
Question is this - could it be a war year power unit?
I"m sure it"s been rebuilt at some point - runs too clean. Can you make a 152 into a 164? Originally more than just a bigger bore in the supers, no? Crankshaft, bearings, etc... I guess I won"t know unless I open it.
Just can"t see why someone would put a 152 block into a super H. Why not rebuild the 164? Unless the block was shot, then it"s availability I guess.
