Re: FARMALL 504 GAS ENGINE SWAP
Posted by richhenry on September 28, 2007 at 22:20:13 from (67.177.156.238):
In Reply to: Re: FARMALL 504 GAS ENGINE SWAP posted by K.B.-826 on September 27, 2007 at 18:43:46:
problem is welded rod bearing on crank,cracked manifold,pistons and rings ,gasket kit so on the parts i am finding are over 1000. with me doing the work just not sure if tractor is worth dumping that kind of money
thank you for reply
