Re: SHE RUNS!!!!!!!!
Posted by n9lhm on October 02, 2007 at 08:56:46 from (69.48.41.2):
In Reply to: SHE RUNS!!!!!!!! posted by Brian Jensen on October 01, 2007 at 21:37:58:
Confirm also that you don"t have one or more fouled spark plugs, or a bridged gap in one. My MD bridged a plug gap with carbon particles when I first tried to start it. They don"t run on three cylinders very well since they don"t have a governor to turn up the throttle on that carburetor. If you have a digital volt meter you can quickly confirm a fouled plug with the ohms function -- a good spark plug should measure totally open. Any measureable resistance indicates fouled.
