Keith, You said: " i took out the amp meter and put in a voltmeter..."
An ammeter is almost an electrical short circuit between its terminals and carries the full alternator charging current to the battery. A voltmeter is almost an open circuit (high resistance) and will carry (at most) about 0.001 Amps reading a full-scale voltage. If I understand you correctly, what you did was to put an effective open circuit (Voltmeter) between the battery and the Alternator by installing a voltmeter in place of the ammeter.
The wires that you removed from both terminals on the Ammeter should all be connected directly together (a short circuit in place of the removed Ammeter) and then add the +(HOT) terminal on the voltmeter with them (i.e. tie all the wires to the Voltmeter (+) terminal). Connect the other (-)voltmeter terminal to a ground (tractor frame).
Your battery seems to be either in need of a charge or has lost its charging capacity due to old age or a defect, according to your description. Hint: Clean your battery terminals & posts to "bright and shiney" and examine the cables for corrosion or broken strands first.
Be Safe! dont work with the wiring without first disconnecting at least the battery Negative cable.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
