Re: 444 battery and various starting/electrical questions
Posted by Casstuba on November 05, 2007 at 14:42:37 from (71.204.196.19):
In Reply to: 444 battery and various starting/electrical questions posted by Casstuba on November 04, 2007 at 19:01:46:
Thanks for the thought. There has been quite a mickey mouse wiring job done to her in the past. I can't even tell what should be where or if it is correct according to the wiring diagram I have.
The coil is only a few months old, and it says use with external resistance.
I'll try to run a few electrical tests on it tomorrow. I should be home early enough to get a few things figured out before it gets too dark.
Brian
