1940 H engine will not slow down to idle
Posted by tackhammertime on December 01, 2007 at 07:59:13 from (70.144.97.163):
Fellows I was out stretching the legs of my H yesterday and noticed it was sluggish. Before we had the head reworked it ran great. My father put the carb back on when we were putting it back together and I noticed that throttle control on the governor seemed to be a little tite. I took the carb and everything back off and then back together with no binding it works free. Now it will not slow down below half throttle. I have not adj anything. I did notice that there are no gaskets on the gov. tube at eather end. Could this be the cause? Also it will die if you try to start off in 5 gear now.
