Posted by sgtbull on December 20, 2007 at 17:16:21 from (166.159.173.247):
Well, I went ahead and took my entire wiring system off my H and started fresh. I priced a cutout from NAPA and nearly had a heart attack... $90. ouch! I bought a solid state one from a local gen/starter rebuild shop for about $20. It's rated at 25 amps and says it will work on 6, 12, or 24 v. systems, and as an experiment, I can live w/ $20 vs $90.. Anyway, I also disassembled the switch and checked all the contacts and all seems good. I rewired everthing according to a wiring diagram I got on this forum, and it seems to work fine, except the charge rate isn't what I would call great. The battery is weak right now, and barely turns the motor over. Would a bad cell, or some other battery malady cause the poor charging rate? It shows virtually no charge on LOW, and only about 7 amps on HIGH charge. Am I overlooking something? I attached a direct ground from the ground side of the field resistor on the switch to insure a good ground, and did the field to ground bypass test, which would slightly increase the charge rate when the switch is on L and makes no difference when the switch is on H... which I suspect is exactly how it should be. I'm gonna put the battery on the trickle charger tonight and see what the morning brings.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
