Mark: I have had one apart, there is some clearence, but I don't think it would be enough to give one a large enough lower shaft gear to reduce enough slower than 1st.
Are you familiar with Hydra Creeper drive. Decent little device, however one could not use the PTO while using the Hydra Creeper. It was basically a hydraulic motor on the PTO shaft and driven by a remote valve on the tractor. It came with a heavy duty clutch release bearing, and one tied the clutch down during use.
I've toyed with the idea of a modified PTO, placing the output shaft close to center rear of tractor. Then use a hydraulic pump and motor to give motive power to wheels. I've looked at placing the motor at front driving bottom shaft of transmission. This would require modification of torque tube.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
