Re: Farmall H ignition
Posted by dan harjes on January 09, 2008 at 13:28:35 from (75.161.129.45):
In Reply to: Re: Farmall H ignition posted by El Toro on January 09, 2008 at 13:08:36:
Ok, I checked the wire-set up. It's battery to the dash-box. out of box down to a "splice" where the alternator (out) is spliced with the switch wire that connect to the (+) of coil. Then only the (-) from coil to distributor. The Dash-box fuse is intact. When I pull the switch on, I do not a large drop to the "discharge" side of guage. I have no lights or anything else hooked that could make a draw that I know of anyway.
