Re: Difference between an A and Super A?
Posted by CNKS on January 26, 2008 at 18:19:06 from (216.144.104.128):
In Reply to: Re: Difference between an A and Super A? posted by mike r38 on January 26, 2008 at 16:47:12:
Factory hydraulics were not an option on the A. The Super A has a hydraulic pump below the distributer and a hydraulic reservoir under the gas tank. The serial tag is in the correct location, it wasn't on the bell housing until the 100 was produced. The A had an exhaust lift as an option, not hydraulic, but worked off the exhaust manifold. It uses a large cylinder, operated by a lever with sort of a pistol grip --I'm not sure what you have, could be an add on of some sort. Owner designed hydraulics can be run off the pto, or a pump driven off the crankshaft. The overlapping T and C is likely an H superimposed over an I inside a C. IHC was the designation when that tractor was built.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
