Posted by tooltime on February 15, 2008 at 17:42:25 from (66.103.167.60):
i have a 340 Utility with a 12 volt conversion. I have timed this tractor a number of times, I put new points and set to .020, new plugs(autolites) and plug wires. new distributor cap/rotor. the coil was still the same 6 volt as was on the tractor before, i added a ballasr resistor from napa. Tractor starts right up, sounds great, but under load or if you drive it begins to miss a bit, i have checked fuel flow and carb. everything seems great. HERES where things get a bit weird for me. I started tractor , put my ear up close to ditributor and coil area, and thought i heard a little snapping noise. I shut the lights off in the shop, and to my surprize you could see little sparks coming from coil end where coil wire goes into coil, also noticed little blue color coming from each of the spark plug wires where rubber boot goes over spark plug.... what is going on here,Bad coil , maybe bad ballast resistor, im not sure what to do here... thanks for any ideas.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
