Re: New Clutch / same old problem
Posted by wood-haulin-cubber on February 22, 2008 at 13:44:50 from (74.69.228.139):
In Reply to: Re: New Clutch / same old problem posted by old on February 22, 2008 at 13:38:53:
thanks for fast response...I just put new fluid in the trans, I use 80-90W...I use NAPPA brand...should I be using something else? ...maybe I don't have enough in? I pull the plug on the top of the trans & remove little plug on lower left side of case, I fill until fluid drips out (maybe 3qrt)....sound right?
