Hey Charles, As for stopping the leaks at the valves, they use standard O rings on each end of the spool. Parts book will give sizes, any good hydraulics shop can fix you up. The usual cause of leakage however, is the unlatching piston inside the big hex head cap on the end. There is a tiny O ring on it which I have never been able to find. Last time I checked, CIH only sold the piston and O ring as an assembly.
As for the banjo fittings, two suggestions. 1. Get rid of them. The valve ports are standard SAE O ring ports, 7/8-14 thread. any hydraulic shop can get fittings from this to whatever you want.
2. If the banjo fittings are good and have about 1.5 inches of straight pipe left on them, You can use a compression hose fittingto hook up a hose. Both Weatherhead and Parker and maybe Gates have them. So it's off to the hydraulic shop again, hope you have a good one around. Leonard
Today's Featured Article - Talk of the Town: Winterizing Engines - To Drain or Not to Drain? - by Russ Berry. What is this strange attraction I have to equipment and machinery? How did I get this way? I came from the suburbs and own a small horse farm in rural Loudoun County, Virginia. You can call me a "weekend farmer." The local farmers do. Does it bother me? No. I am just happy to have their friendship. At least the word "farmer" is in my title. But what is the attraction? How can I explain the sensation and exhilaration I feel when I turn the key and hear the engine come to life (most
... [Read Article]
Latest Ad:
2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell
[More Ads]
