Re: hooking up live hyd. on an H?
Posted by mkirsch on March 28, 2008 at 09:16:27 from (64.80.108.53):
In Reply to: hooking up live hyd. on an H? posted by kwm219 on March 28, 2008 at 08:40:01:
1. You need the right H. It has to have been made after mid-1950, or it doesn't have the right front engine plate or the upgraded timing gears to handle a live pump. Live pumps won't fit on older Hs without changing the front engine cover and timing gears.
2. You need a live pump for a Super H, 300, 350 (gas). These cost about $600 new. Used pumps are less expensive, but they are not rebuildable if you get a bad one.
3. You need a reservoir. Many people disconnect the stock belly pump and use it as a live reservoir. It only holds 6 quarts of oil, though.
4. You need a hydraulic valve.
5. You need a pair of hydraulic quick-connects.
6. You need hoses to hook it all up.
