Re: Super M Clutch: Rejoining Tractor
Posted by P and R Pete on May 20, 2008 at 18:19:19 from (159.240.11.254):
In Reply to: Re: Super M Clutch: Rejoining Tractor posted by old on May 20, 2008 at 18:15:14:
I believe I had heard that one should tighten all the bolts a little at a time, all around, so that you don't risk warping the pressure plate.
Maybe an old wive's tale.
I didn't take any chances though.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
