Re: Reversed H or M
Posted by Janicholson on May 25, 2008 at 13:36:36 from (64.83.197.92):
In Reply to: Re: Reversed H or M posted by NDS on May 25, 2008 at 12:14:19:
Do I remember that the shift mechanism is interference to some part of the process?
and some make/modify the interfering parts. Or is it as simple as stated. JimN
Today's Featured Article - Buying your first tractor: The People You Buy From - by Chris Pratt. If you are a first-time buyer, chances are that you are likely to take the word of the seller on things. This is where the problems start... You have reviewed your implement needs and determined the size of machine that will fit the bill and even made a list of the most desirable models. You checked on the availability of a 3-point hitch for the machines on the list and advertised in your local classified paper with so ... [Read Article]
