706 farmall drawbar+3 pnt.
Posted by honeycreek on June 25, 2008 at 11:15:38 from (12.40.84.157):
Hi,
I am looking at purchasing a 706 gasser with a year-around cab and loader. This will basically be used for snow removal. There is the clevis for the toplink on the 3point but would need to get the arms you can plug into the fast hitch to be able to use it as a three point, I have found them on e-bay for $150-200. My real qeusiton is there will be times where I am going to have to pull a gravity box with 220 Bu in it (I'm a corn burner) and currently the only drawbar on it is the kind that plugs into the fast hitch and it is basically a bar that runs between the two arms and has a hole you can put a hitch pin into. It doesn't look like it is very heavy duty and I do not think it would be the safest thing in the world to be pulling 12320# with, but I could be wrong. Was there ever a factory drawbar (seperate from the fast hitch) that I might be able to find in a junkyard? If so would the 706 have the nessasary holes already there to mount it if I did find one. Thanks for your help.
Randy
