Re: OT: Finally figured out the real reason
Posted by rustyfarmall on August 08, 2008 at 04:46:38 from (209.152.78.71):
In Reply to: OT: Finally figured out the real reason posted by Hugh MacKay on August 08, 2008 at 03:59:50:
And did you ever see the diameter of the drive axles on those front wheel drives? Makes a guy wonder how the car ever made it off the assembly line!
