Re: Farmall 706 LP tractor wont start
Posted by martin simmons 3061 on August 26, 2008 at 15:58:10 from (74.227.33.249):
In Reply to: Re: Farmall 706 LP tractor wont start posted by farmallkid1958 on August 25, 2008 at 18:33:33:
found where the cable goes it was on the right side of the carb.does the cable run behind or in front of the air cleaner. should i be worried about water vapor in the tank when i have it filled. or just fill it and don't worry about it. also what is the starting sequence turn the propane tank knob half or all the way open. press the vaporizer button for 3 seconds start the tractor.
