560 tranny locked up or stuck in high gear
Posted by Gary Hutchinson on December 12, 2008 at 09:56:24 from (192.236.21.148):
Love my 560 but....I was moving snow the other
night with a rear mounted snow blower. I had just finished backing and shifted to go forward. When I let out the clutch, the engine killed. I restarted put the shift in neutral, let out the clutch and it killed again. As near as I can tell, I'm either stuck in a high gear or the tranny is locked up. The shifter will go into
all positions except 4th. Also, when I let the
clutch out with moderate throttle, I don't detect
any slight movement forward which you would expect even if it was stuck for instance, in fourth gear.
