Farmall B Governor rebuild
Posted by Farmalldean on January 21, 2009 at 17:33:42 from (216.228.196.109):
This message is a reply to an archived post by ScottyHOMEy on April 11, 2008 at 14:24:46.
The original subject was "Re: Farmall B Governor rebuild".
I am rebuilding a SA governor. I am not sure what you are referring to when you write "thrust bearing". I see "thrust spring" referred to in my IH Service Manual but not thrust bearing. Can you help me. The governor will not maintain engine speed. The Speed change lever is a bit sloppy in the casing and I think the needle bearings are badly rusted. The will turn with force but I will replace them. I am planning on boring and bushing the speed change lever port and replacing all seals and bearings.
