Ignition systems use less power when running fast than at idle (more voltage is required to jump a partial vacuum than when it is filled with more air/fuel mix) thus the problem is far more likely to be a fuel supply, or carb issue (possibly main jet leanness or plugged up port from sitting. JimN
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
