I had the rear end separated from the transmission on my F20 several years ago. I don't think you have to disassemble anything out of the differential. YOu can separate the whole back end as one unit by unbolting the bolts that attach the differential to the transmission. The main thing is to have the necessary blocking and hoisting equipment to secure everything as you're taking it apart. I believe those are all bolts (not studs) so you'll need to soak them good with PB blaster and then somehow get a wrench on the inside of the differential housing to hold the bold head. BTW,how bad is the leak? I have another F20 that I almost stopped leaking by using JB Quik Weld. This stuff works wonders.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
