Posted by JerryinPa on July 02, 2009 at 05:51:04 from (65.211.106.165):
I replaced a water pump on my Farmall 544 gas. On the old pump, the rear cover plate over the impeller had bolts in all the holes except the one that sat against a rubber grommet between the engine and pump. I got the new pump and it didnt come with a rear cover plate so had to use the one off the old pump. I installed the bolts the same as I found them and after installing the pump and filling the radiator, it is leaking around the rear cover plate in the area where the grommet is with no bolt? I assume I should find another bolt and stick it in the hole behind the grommet? Anyone else ever replace this style water pump before? I'm just not sure a bolt and the grommet will both fit but thats what it looks like it needs to me.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
