Posted by Bruce Arnold on August 10, 2009 at 06:10:38 from (66.103.226.61):
When i push clutch in and try to shift, all i get is gear grind. if i run throttle real low, it sometimes does seem to slow flywheel down where eventually i can shift. usually i'll just turn tractor off, put it in the gear i need, and then start it up. If i start it up with it in reverse, then when i push clutch in, i can shift to any gear with no gear grind. I have tried adjusting linkage to the point where tension is just about to begin on the clutch, but that didn't make one bit of difference. Does anyone have an idea what is wrong? Thanks - Bruce
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
