Re: 140 no compression
Posted by ScottyHOMEy on August 18, 2009 at 12:47:49 from (70.105.243.210):
In Reply to: Re: 140 no compression posted by Brad M-C on August 18, 2009 at 12:37:26:
To your last question, Right? is right.
I asked in my post up above to mkirsch, but you may not have seen it yet. Do you know the history of the machine? Has there been any work done to the tractor lately? It's shapin' up like something is busted pretty badly or something isn't put back together correctly.
If you can see each valve stem moving when the rocker arm bears down on it, you should be finding some compression somewhere even with just a little oil per cylinder on the test. You could have one or two two valves stuck and not popping up completely, but if the motor was left to get stuck, it whould be two valves at most. At any given time in a four-cycle, four cylinder motor, there are only two valves open at any one time -- one for exhaust, one for intake. both valves on the other two cylinders are closed up on either combustion or compression. (the design of the cam make make that not QUITE true, but it's a good rule of thumb that the motor will stop in a position like a describe.
