Re: 140 no compression
Posted by Brad M-C on August 18, 2009 at 12:37:26 from (74.131.54.89):
In Reply to: Re: 140 no compression posted by ScottyHOMEy on August 18, 2009 at 12:21:53:
Rotor lines up with compression stroke on each cylinder. How do I check the valve timing? The rocker is moving every valve open and closed right now with plenty of clearence once closed. If I take the rocker assembly off so none of the valves open and I don't have a ring problem I should have compression...Right?
