CenTex Farmall said: (quoted from post at 19:45:06 09/22/09) How bad exactly is the damage to the old input shaft? Sometimes the bearing race inside the input shaft will take all the beating and is good to go with a new race.
The reason I ask is that after 50+ years the gears will have developed a wear pattern unique to themselves and you can expect there to be some whine once you get going again. It won't hurt anything, but just be aware that you will likely get some noise.
As for the ring and pinion, if it was my tractor I would try my best to match up the existing patterns on the gear rather than set the specified backlash. Some of the tractors I've seen had obvious wear on this gear set and some are hardly noticeable.
Look very closely at the pinion and look for a slightly depressed area that is more or less centered on the teeth where the ring gear teeth contact vs. the extreme ends of the gear teeth where there will be no wear.
What is likely is that in order to get the backlash "in spec" (without touching the carrier shims) you will have to shim the pinion so far to the rear that the actual contact points on the gear teeth will be on a high spot and the load will be highly concentrated and be more likely to result in tooth failure. In order to try to hit the specs properly you will also have to shim the carrier left and right.
Certainly it is better to have the backlash within spec than not, but if I had to choose, due to combined wear between the ring and the pinion, I would go for a best match of the pattern.
Having more backlash than what the book says is not nearly as bad as it sounds. Since the tractor is under a steady load for the overwhelming majority of the time, the gear teeth are not ratcheting back and forth.
Before I forget, to answer your original question the backlash is .008 to .012
The half inch bolt that holds the roller cage bearing on the front of the main shaft was off but still inside the back of the gear on the drive shaft since it is a blind hole. When this happened, the cage bearing moved half way off the shaft but continued to turn. the front half of the nose is roughed up and the diameter is smaller than the back half. I was uncomfortable using the old shaft and putting a new $103.00 bearing on it since only half the surface of the nose would be in contact with the inner race. So, I went shopping for a shaft. I found one still in the tractor. I bought the main shaft and the drive shaft which still had the bearing and race. They looked in good shape. I understand what your saying about the wear on the gears. I hadn't thought about that but will look closely at each gear today for any wear spots. On that .008 to .012. Is that the clearance between two teeth between the ring and pinion. Thanks, Gmercer
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
