Re: Rebuilt 340 that smokes, engine C135
Posted by Janicholson on September 25, 2009 at 06:10:31 from (199.17.6.222):
In Reply to: Rebuilt 340 that smokes, engine C135 posted by jdbrad1 on September 25, 2009 at 05:57:47:
Were the rings checked for end gap in the cylinder? if not, there is no way (but faith) to tell if they are correct. If wrong they will not have correct tension in the cylinder, and gaps at the end.
Is the oil ring expander spacer butted together holding the scraper rails in place? if not it will over oil the walls.
If the cylinder walls were just honed, and the ridge removed, the oil burning will not be curbed due to taper in the cylinder. JimN
