Re: SA electrical problems partially solved
Posted by John T on November 04, 2009 at 14:25:36 from (66.244.97.31):
In Reply to: SA electrical problems partially solved posted by Mark on November 04, 2009 at 13:17:14:
I DO NOT recommend you unhook an alternator when running, I hope it isnt damaged !!!!!!!!!!
As far as the coil the LABELS can be confusing:
A full true 12 volt coil (NO ballast required) may be labeled "12 volts" or "12 volts NOT for use with ballast" soem call tehm internally ballasted
A coil labeled "12 volts for use with external ballast" is in reality a 6 volt coil and needs the ballast just as it says
If the new coil you bought is a full true 12 volt coil YOU DONT USE AN EXTERNAL BALLAST
I figured it had to be an out of register out of time (as so many of us posted) situation if the coil fired but there were no plugs firing
Thanks for the feedback
Got to run I will check back later
John T
