Re: Starter solenoid on my 400
Posted by El Toro on November 21, 2009 at 07:17:57 from (74.103.74.58):
In Reply to: Starter solenoid on my 400 posted by SDE on November 21, 2009 at 06:52:11:
third party image
You need to make sure you're getting 12 volts to the S terminal on the solenoid when you twist the key to the start position. The other terminal should have voltage all the time since it feeds your ignition switch & voltage for the lights. Hal
