Re: 300U shifting problem(all to the rear)
Posted by Janicholson on April 19, 2010 at 06:17:37 from (199.17.6.222):
In Reply to: 300U shifting problem(all to the rear) posted by BMD on April 18, 2010 at 20:34:09:
I am confused by the paragraph (near the end) starting with "If each set of three rails and forks" There are three rails, and three forks.
There is a slot in each rail that the tip of the shifter moves in. It moves one entire rail forward and rearward in 1-R It is the right most rail looking down in the hole while seated.
Gears 2-3 ues the center rail and 4-5 use the left rail.
The slots must be aligned when in neutral to allow any rail to be selected.
If the rails can be moved into all gears with a screw driver, it is the shifter that is at fault.
It may have a very worn pivot pin, or it could be bent, limiting its travel. I hope this helps. keep in touch, Jim
