Posted by ScottyHOMEy on May 17, 2010 at 19:03:34 from (64.222.223.103):
In Reply to: Re: farmall b posted by cuttman on May 17, 2010 at 18:50:49:
Battery start, yes, as opposed to starting with a hand crank. The ignition is a magneto. The magneto is totally isolated from the battery.
Trick to it is that both battery and magneto ignitions have distributors , complete with points and condensers-- that would be the part with the cap that distributes the spark around to the various plug wires at the proper time. The difference is the source of the spark. On the magneto, the guts of the assembly between the distributor generate the spark as the motor turns. There is actually a coil in there, though of a different design than the canister coil of the battery ignition. So the governor gear turns both the magneto (a magnetized shaft spinning inside the coil) and the distributor.
On a battery ignition, the governor gear simply drives the distributor so that it can rotate and do its job. The coil is external and with the points and condenser works to create the spark with electrical power coming from the battery.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
