606 front pivot rebuild
Posted by reltor on August 14, 2010 at 07:04:58 from (71.60.191.211):
I am making progress on the front end rebuild of
my 606, but have run into a new problem. I
rebushed the front bracket and have a new pin that
is 1.75" I can get the front axle on, but when I
go to attach the link arms of the axle underneath,
they are under extreme tension to get bolted up.
If I attach the rear axle link first the axle hole
is at the wrong angle(pointing slightly at the
ground in front of the tractor.
I am thinking I will have to reduce the diameter
of the pin where it goes through the axle to
relieve this pressure when the link arms are
bolted up. This will give a sloppier fit in the
pin axle interface though.
Has anyone had experience with this?
Should those axle link arms be under some pressure
when bolted into position?
Does anyone know the factory diameter of the
factory pivot pin and axle pivot hole?
Thank You
