Re: 606 front pivot rebuild
Posted by Weldon K on August 14, 2010 at 08:08:24 from (98.16.27.102):
In Reply to: 606 front pivot rebuild posted by reltor on August 14, 2010 at 07:04:58:
I looked at parts page for 606 and 504.They use the same pivot pin. I have a 504 and looked at it but cannot measure pin dia. in place but it appeared that it would be 1.75" . Axles are similar though axle number is different due to 606 axle bracing yoke being longer due to 6 cyl. engine vs. 4 cyl. in 504 . If you have a new pin and bushings from Case IH then it is the right one. There should perhaps be some tension when you bolt up the axle bracing yoke to the underside of the clutch housing, but I would not think it would or should be much. Do not put a smaller dia. pin in the pivot. Perhaps you could heat and bend the axle bracing yoke in the vicinity of the ball to make things align better.
