Re: Distributor work
Posted by AceS on September 07, 2010 at 16:39:56 from (64.5.70.177):
In Reply to: Distributor work posted by David A.. Smith on September 07, 2010 at 16:01:51:
David You can take it apart at the arrow next to the distributor. But first remove the distributor cap and turn the motor over so that the rotor is pointing to number one plug wire which is at 1o clock. then don't turn the motor untill you put the distributer back on.
Today's Featured Article - Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche ... [Read Article]
