O/T Chev 235, 250 and 292 6 cylinder engines ???
Posted by old on January 02, 2011 at 14:34:12 from (4.245.12.1):
Just checking to make sure I am remembering right. The heads from all 3 size engine will work on all 3 right??? Also the cams, rod, pistons and main and rod bearings are the same but the crank shaft is different in all 3 right?? Building a 292 but only have heads off of the 250s on hand and just want to make sure it will work so I do not get it on and then find it will not come close.
Thanks
