Re: Farmall C or Super A Hydraulic Pump Rebuild
Posted by gene bender on January 04, 2011 at 05:50:02 from (67.55.227.196):
In Reply to: Farmall C or Super A Hydraulic Pump Rebuild posted by ihtrucker on January 03, 2011 at 06:37:24:
Depending on the pump there would either be an O-RING or a seal. You wont know till the pump is removed and if the shaft is worn in the seal area you need a speedy sleeve as now your fluid is going into the crankcase. If you chack the oil you will probably find it over full. If its an o-ring you will need to enlarge the hole on the housing to allow for the speedy sleeve. If its a seal the sleeve will work without enlarging the hole if did a bunch of them.
