Re: No oil pressure.
Posted by El Toro on February 12, 2011 at 07:51:49 from (108.3.200.96):
In Reply to: Re: No oil pressure. posted by CNKS on February 12, 2011 at 06:30:33:
Ask the shop where you had the hot tanking done if they removed any pipe plugs. I think you would see oil dripping if a plug was left out. Hal
PS: Did you remove that relief valve & spring from the pump? I would take another look at that pump.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
