actual bore diameter of a 560- 282 diesel without sleeves?
Posted by NolanJae on February 28, 2011 at 12:33:40 from (97.127.81.160):
I'm trying to find out what the bore diameter is of a 282. The IT book says 3 and 11/16ths but that is with the sleeve in. I'm looking for the bore size without a sleeve in the block. and or what is the O.D. size of a standard sleeve is? With the answer to those questions does anyone know what the allowable size difference between the actual bore and the O.D. of the sleeve should be?? I know they are a dry press fit but what does that translate into for measurements?
I measured each bore (without sleeves) and I'm seeing if I need to order oversized sleeves but cant do that without knowing what the original size is?
