Re: 560 Hydraulics cant hold implement up
Posted by Janicholson on March 21, 2011 at 12:09:34 from (199.17.6.194):
In Reply to: 560 Hydraulics cant hold implement up posted by heyiou on March 21, 2011 at 12:01:41:
The most common issue is bypassing lift cylinder. If the piston leaks the fluid just goes from one end to the other, letting the implement drop. There could be check valve issues or internal valve leaks, but less likely.
Use a jack under the Mower to lift until the pressure is off of the hitch. Detach the lines and plug them. Lower the jack. If the mower drops as before it is the cylinder packing, if not it is in valving. Jim
